Power Washing Brick House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2006, 02:12 PM   #1
hello,
i want to power wash my brick house and vinyl window shutters. will this damage the mortar between the bricks? the house was built in the mid '50s, and all the mortar looks to be pretty solid. also, i would imagine the power wash will remove any old, or loose paint and caulking too, right?
bob
bobo is offline   Reply With Quote
Old 09-24-2006, 03:36 PM   #2
Painting Contractor
No one here can answer the "damaging the mortar" question, but if you start and some falls off...then move back with the wand or just be more careful. Also, yes older and loose paint will come off...I usually dont have caulk come off, but you never know.
Remember to wear your "duck suit"...I do~I never get a drop of water on me!
Paintguy26 is offline   Reply With Quote
Old 09-24-2006, 04:38 PM   #3
Rewards Points: 1,232
As a rule, powerwashing is not good for any masonry surface. That said, if you were to use something like Jomax as a cleaner and a fan tip you will probably be OK.
Tscarborough is offline   Reply With Quote
Old 09-24-2006, 05:53 PM   #4
ty for the replys! i think i will play it safe and just use the ol garden hose with a soap dispencer attachment!!!! thanks again for the info!
bob
Brick face house clean up - improvement jovo14 Building & Construction 1 08-09-2007 03:40 PM
Brick a house 3DPiper Building & Construction 2 03-28-2007 03:14 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
