Power Washing Aluminum Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 07:52 PM   #1
WindowTreatment Installer
Power washing aluminum siding
I have an aluminum sided 2 story house. The north side has moss or some kind of green stuff grown in bloches. I plan on power washing it off as soon as the weather warms up. My question, is it ok to power wash siding and is there a right or wrong way. Also is there something I can apply so it doesn't come back.
bobtheblindguy is offline   Reply With Quote
Old 05-06-2011, 08:53 PM   #2
Rewards Points: 5,336
Use an algaecide in the power washer.
Due to the lack of Sun on those exposures, this will be a regular task.
Ron
Old 05-06-2011, 10:36 PM   #3
And when you spray the siding always do it with the sprayer pointing down so you don't force water up under the siding.
hayewe farm is offline   Reply With Quote
Old 05-07-2011, 06:35 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
i wouldn't recommend a power washer at all,gentle cleaning and rinsing with a garden house is all you need
Tom Struble is offline   Reply With Quote
Old 05-07-2011, 01:45 PM   #5
As an alternative to powerwashing, they sell hose end sprayers with an algeacide in the container. They remove the residue, but they might not reach as high as you need without a ladder.
Ron
Old 05-07-2011, 02:36 PM   #6
Hi Ron...Not sure if this would be powerful enough to remove the moss. But I think your right that this will be a regular task.
Washing the side of the house by hand would be dangerous and very time consuming.
Old 05-07-2011, 04:55 PM   #7
better than blowing the paint off your house
Old 05-07-2011, 09:04 PM   #8
Is it moss or algae? The chemical kills the algae, it doesn't pummel it off the wall.
Ron
installing vinyl siding over aluminum siding brad7359 Remodeling 8 07-24-2010 06:28 AM
Aluminum Siding in Contact electric1 Electrical 1 03-31-2005 07:48 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
