Power-actuated Nail Size For Sole Plates - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2008, 10:31 AM   #1
Rewards Points: 1,062
Question
power-actuated nail size for sole plates
when i use 2.5 in, the nail goes all the way in but if i use 3 in a small section sticks out undriven all the way. is it okay to use 2.5 in coated nails for pressure-treated 2x4 sole plates ?
thx,
- a-
Old 06-03-2008, 10:45 AM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
general rule of thumb is that the fastener be 2x the thickness of the material being nailed, using a 2.5 inch nail is ok though if you are going into pressure treated be sure they are rated for such use as if not they could rust off. Most pressure treated now I think is ACQ, so we always use ACQ rated nails to be safe.
USP45 is offline   Reply With Quote
Old 06-03-2008, 11:09 AM   #3
Registered User
Termite's Avatar
Nope! The International Residential Code requires 16d nails to secure sole plates. The nails should be spaced no further apart than 16".
Your nails should penetrate joists or blocking, not just the plywood. If it is an exterior wall you should be nailing into the rim joist as well. Done correctly, you won't have nails sticking out anywhere unless you're building in interior wall that runs parallel between floor joists.
Old 06-03-2008, 11:35 AM   #4
how long is a 16d nail ? i am fastening into concrete. i have tried multiple guns and none will drive a 3 in nail all the way in so that the nail head is flush with the top of the sole plate. the best i can do is 2.5.
Old 06-03-2008, 02:12 PM   #5
Registered User
Termite's Avatar
My bad! I failed to read the original title! I thought we were talking wood framing. Duh!
You can use whatever nail length gets the job done, as there is no code requirement for nail length at a sole plate over concrete. If your ramset gun isn't getting it done, try hand-driving "cut nails" for masonry. They work great.
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
Best Practices for Framing Nail size jms5883 Remodeling 7 01-31-2008 12:37 PM
Losing power, length? size? Kellxr7 Home Theater 5 12-05-2007 12:19 AM
Roofing nail size scarrell Roofing/Siding 3 03-29-2006 12:52 PM
