Pouring A Sidewalk - Piles For Frost Heave? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 05:52 AM   #1
Pouring a sidewalk - Piles for frost heave?
Like it says I am going to be pouring new sidewalks. Will it be sufficient to pour piles down past the frost line & then pour the sidewalk on top? Or should I be putting gravel down as well?
S.
sharp21 is offline   Reply With Quote
Old 11-13-2011, 06:50 AM   #2
concretemasonry's Avatar
Rewards Points: 2,626
No ned for piles and any excessive depth. A sidewalk is a "floating structure", just like a street or highway. Small amounts of movement are usually tolerated. Make sure you have some well draining soild road base, etc. under the sidewalk especially if you have moist and/or sub-base.
Make sure you have a joint between the sidewalk and a structure.
Dick
concretemasonry is online now   Reply With Quote
Old 11-13-2011, 09:15 AM   #3
Do you mean tie the sidewalk to the house with rebar?
S.
Old 11-13-2011, 09:25 AM   #4
Rewards Points: 2,240
No -
I'm pretty, sure "concretemasonry" is referring to an "expansion joint"
type of material.
You probably don't want to "pin" the sidewalk to the house (with rebar) -
as stated above - the sidewalk is a "floating structure".
RF
rossfingal is offline   Reply With Quote
Cracked, Sunken, Too high Sidewalk! fake50 Landscaping & Lawn Care 0 04-13-2010 01:01 PM
Advice needed for draintile under sidewalk dgbehrends Landscaping & Lawn Care 5 11-17-2009 12:03 AM
Sidewalk drainage issue! Bcoleman6 Building & Construction 1 07-07-2008 02:17 PM
