#16 | |
Pouring Patio Slab and Post Footings Question
Hi GBR,
Thanks for the details. As for method #2 , the Simpson Strong Tie does have a model that gives you the same 1" metal bracket (see image below)as the hardware noted in Method #1. So with this model, one can go P.T. or non-P.T. However based on what Willie said, I will mostlikely forgo using this as its a bit more technical. Quote:
Thanks again GBR, Moe Last edited by average_male; 09-23-2009 at 07:43 PM. |
#17 |
Old School
No reason to shy away from any particular installation. Just be sure to get whatever you put in straight, plumb, and square.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#18 | |
Xtreme DIY'r
Pouring Patio Slab and Post Footings QuestionQuote:
....I've tried Google sketchup....not used to using it
| Display Modes | |
| slumped patio fix ?? | houser | Building & Construction | 5 | 03-18-2010 07:25 AM |
| Making a channel in a post tension slab | firehead67 | Building & Construction | 11 | 08-22-2009 02:38 PM |
| Post Tension Concrete Slab | jeff gloeb | Flooring | 1 | 05-27-2009 11:11 AM |
| replace porch post on concrete slab | maa40 | Building & Construction | 2 | 03-23-2008 11:50 AM |
