Old 09-23-2009, 01:21 PM   #1
Pouring Patio Slab and Post Footings Question
Hello All,
I am going to put in a covered patio. Question is, what is the preferred mthod of putting in post footings between the two methods (after the slab pour versus before the slab pour ).
Method 1 (After pouring the patio slab)
Pour the concrete for the patio slab and after the concrete drys for a couple of days, drill and place anchor bolts and place Simpson Strong Ties for your posts. (See image Method 1 Below)
Method 2 (Before pouring the patio slab)
Before pouring the patio slab, create forms for the post(s) and first pour the concrete for just the post footings using "Method 2 Hardware" noted below, and let dry, and then pour the main patio slab. So this method you will have a number of footings set higher than the patio slab that the post will sit on top of.
Method 1 Hardware:
Method 2 Hardware before patio concrete slab:
Thanks,
Moe
average_male is offline   Reply With Quote
Old 09-23-2009, 01:37 PM   #2
#1 But instead of drilling later put the anchor bolts in the slab when it is poured.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-23-2009, 02:37 PM   #3
Thanks Joed,
Can you expand as to the benefits of this approach versus the other method?
Thanks,
Moe
Old 09-23-2009, 02:42 PM   #4
Old School
Willie T's Avatar
Originally Posted by average_male View Post
Thanks Joed,
Thanks,
Moe
  1. You don't have to drill anything.
  2. The anchor has a 90 degree turn in it for better holding force.
  3. Even if the anchor SHOULD work loose in a wind storm, it's still going to hold things down... whereas a drilled anchor will lose it's effectiveness as soon as it loses any grip on the concrete.
Willie T
Old 09-23-2009, 02:59 PM   #5
Willie,
Thanks for your input. However, I am not sure which method you are in support of, sounds like method #2. Not sure what you mean by "90 degree turn in it". Can you expand on that?
Thanks,
Moe
Old 09-23-2009, 04:00 PM   #6
Old School
Willie T's Avatar
Yes, #2. These anchor bolts come in many lengths to suit your needs.
Willie T
Old 09-23-2009, 04:28 PM   #7
Ah, interesting. So that's how it's done.
Thanks Willie!
Old 09-23-2009, 04:48 PM   #8
Old School
Willie T's Avatar
This is how you suspend the bolt in the concrete pour.
Drill a long ( 12") piece of plywood with a hole the bolt will just fit through.
Put the bolt through, and slip on the washer, then run the nut down to give you the height of thread sticking above the form board you desire. (Be accurate here) Remember, you're measuring from the BOTTOM of the plywood.
Nail the plywood to the top of the form board in the correct (measured) position........ (I'm only showing a single form board actually attached for this corner so you can see how the bolt hangs.)
For side form boards, you simply make the plywood a little wider so the bolt is out far enough to be where you want it.
That orange thing in the background is nothing more than an example of how you would drill the plywood.
There is a slightly more complicated way of suspending that bolt, using two nuts, one above the plywood, and one below it. But this method will do for you. Just be sure the bolt is vertical when the pour is done.
Willie T
Old 09-23-2009, 05:40 PM   #9
Old School
Willie T's Avatar
One thing about doing this "bolt" method is that there is usually some "play" allowed in the hole/s in the bottom of your "method #1" hardware.
"Method #2" insists that you be 100% accurate when you place that bracket in the concrete. That is sometimes hard to do.
Willie T
Old 09-23-2009, 05:53 PM   #10
a masterful explanation by a true craftsman, willie
itsreallyconc is offline   Reply With Quote
Old 09-23-2009, 05:58 PM   #11
Old School
Willie T's Avatar
By the way, some people will tell you to just pour the concrete, then simply poke the bolt down into the wet concrete, and "joog" it around a little till it stays put. This will do fine for very rough work, but not for hitting holes in future bracket installations. Besides, it is not accepted workmanship at all... it has a tendency to create voids down inside the concrete. Best to measure accurately, and hang the bolts.
Willie T
Old 09-23-2009, 05:59 PM   #12
Willie,
While reading other posts, I found your other postings had a wealth of information laid-out in a very clear and detailed manner. So thank for providding the same level of input to my question. It's greatly appreciated.
Also, where do you get those figures? Did you create those?
Thanks,
Moe
Old 09-23-2009, 06:00 PM   #13
Old School
Willie T's Avatar
I learned formwork early... on parking garages and bridges.
Willie T
Old 09-23-2009, 06:02 PM   #14
Old School
Willie T's Avatar
Willie,
Thanks,
Moe
Helping is why many of us are here.
The picture of the bolt came directly from a Google "Image" search of the www.
The other stuff is just some simple drawings I throw together with Google SketchUp.
Willie T
Old 09-23-2009, 06:35 PM   #15
You have to decide what you are looking for in the two different post bases. #1 could be a non-treated post sitting on 1" high plate to protect from water splash (check with your local Building Department), or a p.t. post. This design has little or no resistance to lateral (side) forces. The hold-down in a high wind is rated from 550# to 2100# using nails or bolts. #2 has to be a pressure treated post as it will sit on the metal plate on the slab. This has the advantage of side resistance for stiffening. It has a rating for hold-down of 4200# minimum with bolts. So if you are trimming out the posts, #1 would be much easier than the bolts, washers, nuts and side flanges in #2. Remember to thicken the edges of the slab at the posts for load, possibly using a vapor barrier (6mil. plastic) under slab, possibly 2" insulation at perimeter (cold locales), and good gravel base underneath with the soil sloped for drainage.
Be safe, Gary
GBR in WA is offline   Reply With Quote
More On This Topic
Fox and Geese is a board game that uses marbles. The play is like a one-sided checker game, the fox can jump the geese but the geese can only take defensive measures and block the fox. When the fox jumps the geese they are out of the game. The geese can... Read More »
Inspecting Diving Boards
Inspecting Diving Boards by Expert Village
How you doing? I'm Bobby Larew. I'm talking about diving today. Before you get on the board, you really need to inspect the board to make sure that it's in proper working order. You want to make sure that the board is going to be stable. You want to make... Read More »
Breaking suspended boards with a partner! Improve your martial arts skills with instructions on board breaking techniques. Read More »
Use suspended breaking to break two boards! Improve your martial arts skills with instructions on board breaking techniques. Read More »
Do suspended board breaking with your elbow! Improve your martial arts skills with instructions on board breaking techniques. Read More »
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Making a channel in a post tension slab firehead67 Building & Construction 11 08-22-2009 02:38 PM
Post Tension Concrete Slab jeff gloeb Flooring 1 05-27-2009 11:11 AM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
