Pouring A Level Concrete Slab Over Sloped Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2008, 10:32 AM   #1
pouring a level concrete slab over sloped concrete
We need to pour a level concrete slab to accommodate our new hot tub. This slab will be poured on top of an existing sloped (for drainage) concrete terrace. The size of this pad will be 84" x 84". How thick should the thinnest part be? (the max thickness at the lowest part of the slop will be approx 4" thick) How many bags of premix concrete will it take to do an area this size? Any other things we should know about before pouring this slab? Thank you.
Jayne is offline   Reply With Quote
Old 05-09-2008, 11:36 AM   #2
concrete premix
You'll have about 16 cubic feet of concrete (less depending on how much slope there is).
Concrete can come in different size bags, so you'll have to determine the amount per bag. (80# bag, 60# bag, 40# bag..) often 1/3 to 2/3 cubic feet per bag. it'll be listed on the bag.
It's a lot of work! If you are in an area where there is frost for part of the year laying a slab on another slab may create problems.
bob
http://www.floridaterrazzorepair.com
harvster is offline   Reply With Quote
Old 05-09-2008, 08:11 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
7'x7'x4" = 16.33 CU.ft An 80lb. bag yeild 1/2 Cu.ft you will need 32 bags. Minus the pitch of the existing slab. I would pour a bonding agent on the existing slab before I formed and poured the new slab. just my 2 cents .good luck Bob
Old 05-09-2008, 10:29 PM   #4
remodeling pro
I'd suggest looking in the phone book for a "short loads" concrete supplier, trade lingo for small quantities. You will pay a little premium for the service, but it is well worth it IMO. As you see from the math of others, that is a lot of bags to haul from the big box, handle, and pour. I would start with no less than 3" at the THINNEST part. The level top of the forms will determine the thickness at the down slope end. Use a bonding agent as suggested, and some reinforcing wire, even if just a pieces of "hog wire" from the big box, tied together with baling wire. Keep the wire a couple of inches in from the edge of the concrete and as close to the center of the depth as you can, for rust purposes.
troubleseeker is offline   Reply With Quote
Old 05-11-2008, 09:55 AM   #5
your new slab'll weigh enuff so it won't move,,, therefore, i wouldn't use a bonding agent,,, rather, i'd wanna be sure my new o'lay slab did NOT bond,,, 3" at the thinnest - wended wire fabric if you wish but i'd go w/fiber,,, DO be certain your new joints're cut above existing & add as rqd for proper jnt practices,,, if you've never done this type of overlay ( bonded OR unbonded ) work, maybe its best to follow the other posts.
yes.itsconcrete is offline   Reply With Quote
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 08:40 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 06:14 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 09:52 AM
