Pouring Concrete In Fire Pit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2008, 01:13 PM   #1
Clueless and Alone
SweatEquitySux's Avatar
Send a message via AIM to SweatEquitySux Send a message via Yahoo to SweatEquitySux
Pouring concrete in fire pit
I have a tractor tire rim that i buried to use as a fire pit. I like to scrap up the ashes and use them in my garden. I was thinking that it would be easier to clean out if I had a solid bottom in it. However, I was told that regular concrete would explode due to trapped moisture. What is the best way to do this? Pour the concrete and in-bed some fire bricks into it? Thanks!
SweatEquitySux is offline   Reply With Quote
Old 10-10-2008, 03:03 PM   #2
Registered User
Termite's Avatar
Firebrick with refractory mortar would be the best way to go. Refractory mortar is high-heat resistant, and is for use in fireplaces.
I don't think concrete would explode. It would certainly deteriorate after repeated fires though.
Old 10-10-2008, 04:10 PM   #3
It will explode, trust me on this one. Not so much because of moisture but because of air bubbles.
I have treated people who had chunks of it fly off and cut them. Nothing serious and the people who called 911 just panicked because of the blood.
I have also seen bridges made of concrete explode and big chunks fly off because a semi hauliing gas, tipped and caught fire.
Granted this was a really hot fire but having hot coals will do the same as the concrete heats up.
I have also seen rocks explode in a fire ring. Most of the time they just crack and make a pop when they do but every now and then one will send some shrapnel flying.
Firebricks would be your best bet as thekctermite said.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
pouring a concrete driveway drewhart General DIY Discussions 20 08-01-2008 03:30 PM
pouring a level concrete slab over sloped concrete Jayne Building & Construction 4 05-11-2008 08:55 AM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 07:40 PM
need advice befor pouring concrete in barn abtankerman General DIY Discussions 4 11-03-2007 04:59 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
