Old 04-29-2011, 04:12 PM   #1
Pouring concrete below a water line
I will be building a deck off of a retaining wall I constructed last year. The retaining wall is at the water line of the lake. i will be attaching one side of the deck to the retaining wall and digging and pouring concrete posts for the middle and other side of the deck. My question is: When i dig my middle posts, I will not get far before I'm below the water table. How do I set concrete if the hole I'm pouring into is full of water?
Thanks in advance for the help
leaman is offline   Reply With Quote
Old 04-29-2011, 05:40 PM   #2
Civil Engineer
Concrete sets fine under water. Order a slightly dry mix, place it in a sonotube, the concrete will displace the water and the part of the concrete below the water table will set up very nicely.
Old 04-29-2011, 06:40 PM   #3
Tileguy
Bud Cline's Avatar
Yup, believe it or not.
Years ago I poured many a temporary concrete boat ramp for the Army Corps of Engineers. Poured right into the water and bull-floated under water. When the lake level would drop and a proper ramp could be built we removed the temporary. I was always amazed at the condition of the ramps. They weren't very pretty but they were tuff as could be to break up and remove.
Old 04-29-2011, 10:01 PM   #4
Pretending to be Retired
Many many bridges are built this way. If I were doing your project, I would slide the concrete down the side of the form continuously and try to keep the water and concrete from intermixing. As the concrete fills the hole the water will rise and flow out the top. Or you could make concrete piers on land, and maneuver them into place.
BigD9 is offline   Reply With Quote
Tags
concrete, posts, water
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 12:39 PM
Plumbing line in exterior concrete for pool Hawk334 Plumbing 4 07-04-2009 11:13 PM
