Pour Footer In Sections? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 10:06 AM   #1
Pour footer in sections?
Is there a preferred method for handling a cold joint in a footer?
I'm thinking of making a plywood end cap that has holes for the rebar to pass through and a wood block on the pour side to make a keyway for the next pour.
walkman is offline   Reply With Quote
Old 05-17-2009, 12:08 PM   #2
Builder and Remodeler
JohnCarpenter's Avatar
Why would you want to pour in sections?
Need more information.
______________________
Johnny Jackson
http://www.jljacksonremodeling.com
JohnCarpenter is offline   Reply With Quote
Old 05-17-2009, 12:45 PM   #3
what john said footers have NO jnts,,, on the off chance you're placing a foundation where you can't get redimix mud, place the footer in sections w/header as you outlined AND include the keyway,,, wrap keyway & header w/wax'd paper which'll help you release the next day
yesitsconcrete is offline   Reply With Quote
Old 05-17-2009, 06:08 PM   #4
I'm working in a space where I can't get redimix so I'd work from bags.
If I do the work myself I wouldn't be able to get it all done in one batch so I was considering breaking the job into sections.
Thanks for the wax paper tip.
Old 05-17-2009, 07:20 PM   #5
Rewards Points: 95
On large jobs footings are poured in sections all the time. The method you described will work fine.
NJ Brickie is offline   Reply With Quote
Old 05-17-2009, 07:30 PM   #6
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
Brickie is correct. And keys are highly recommended.
Aggie67 is offline   Reply With Quote
Question on Monolithic slab - Pour all at once? seth Building & Construction 15 05-06-2009 03:36 PM
Footer for screened in porch RocketRon Building & Construction 2 12-16-2008 02:54 PM
Need to pour a footer Lawnworks Building & Construction 1 10-01-2008 06:43 AM
Footer deere2440 Building & Construction 7 03-01-2008 08:54 PM
Undercut footer billinak Building & Construction 3 03-18-2005 06:34 PM
