Posts Into Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 02:00 PM   #1
Posts Into Concrete
Hi,
I would like to install a short run of handrailing up some 2" thick bluestone steps, (4 steps) that are set in stone/concrete. For the posts connecting the handrail/ballasters I was thinking of attaching two 4x4 PT posts (one at top and bottom) to the bluestone using an anchor plate. I wanted to drill into the flagstone, down into the rock/concrete, put in epoxy, a sleeve, then a bolt to hold the plate down. My question, is this doable? Is that strong enough for a handrail? I can't really dig hole outside the steps for the posts, because there is a lot of uneven concrete and rock. Any thoughts?
prod69 is offline   Reply With Quote
Old 04-01-2010, 02:09 PM   #2
Remodeling Contractor
depends on the post supports you use. But yes it is doable.
Old 04-01-2010, 05:48 PM   #3
kwikfishron's Avatar
Rewards Points: 620
You can’t “easily” dig to the outside but that’s were I’d like to see the post.
Nothing you do on top will be "Rock Solid".
A picture would be nice.
kwikfishron is offline   Reply With Quote
Old 04-01-2010, 06:22 PM   #4
build a hollow box post with a 1" piece of allthread rod. rod drilled into tread/ step area with hydraulic cement poured around it at the step. I like to drill the hole large enough to have a nut with washer poured into the hole threaded on the rod. then a box post with a rabbit/mortise at the top that a plate will sit on with a center hole for your allthread to go thru. washer and nut and torque will lock post in place. finish post with top cap of your choice
The older I get the better I was
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 05:39 AM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 6 04-01-2010 06:41 PM
4x4 posts on top of existing concrete pad qcliffy Building & Construction 7 12-26-2009 09:54 PM
How do I retrofit-anchor posts to concrete? wcap Building & Construction 2 10-18-2009 10:42 AM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 02:14 PM
