Old 01-29-2011, 05:09 PM   #1
Question
posting housewrap
can i use 3/8 staples to affix Tyvec housewrap to 7/16 OSB ? and should i use a regular stapler (grip) or the hammer-like one for roofing? i have both.
also, i notice they sell some tape for $11 at HD, apparently to seal the joints between. is that really necessary to use, i'd like to save $11.
Old 01-29-2011, 05:20 PM   #2
Tom Struble's Avatar
posting housewrap
http://www2.dupont.com/Tyvek_Weather...WRB_K16282.pdf
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
amakarevic (01-29-2011)
Old 01-29-2011, 05:46 PM   #3
Carpenter
dtsman's Avatar
posting housewrap
The swing stapler will be fine. Taping the joints is imporant to maintain a consistent sealing. I know your thinking of just using alot of staples to close the seam, but I would consult the link above and get it as close to right as you can. Once covered there's no going back.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
The Following User Says Thank You to dtsman For This Useful Post:
Old 01-29-2011, 06:41 PM   #4
posting housewrap
Do it right (as above) and seal the window and door penetrations well. Thats the weakest spot
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Old 01-29-2011, 08:48 PM   #5
Carpenter
dtsman's Avatar
posting housewrap
After some thought, if you absolutely don't want to buy the tape, double fold the seams and then staple. House wrap is more about wind penatration than moisture.
Bo
Remember,
(Red Green)
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 09:50 PM
housewrap amdhp Remodeling 8 10-20-2010 10:43 PM
Housewrap over interior basement insulation gpellock Building & Construction 2 10-11-2010 02:21 AM
tyvek housewrap in the ceiling rodeo Building & Construction 6 02-06-2008 12:21 PM
Posting Quotes?? Jerry8C Site Help and Suggestions 9 02-04-2008 10:26 PM
