Post-tension Concrete Foundation Extension - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 06:26 PM   #1
Question
Post-tension concrete foundation extension
Hi! I'm planning to build an addition onto my home and therefore need to extend the foundation. The existing foundation is a post-tension concrete foundation but the extension would be a standard rebar-type slab. Is it OK to pour another concrete foundation alongside an existing post-tension concrete foundation?
I know that it is OK to join concrete slab foundations but was wondering if there would be a problem with a post-tension type.
I realize that great care would need to be exercised when drilling holes in the existing foundation for the rebar pins to join the 2 foundations. Are there any other tips I should consider? Thanks.
woody9911 is offline   Reply With Quote
Tags
addition , foundation , post-tension
affixing PT 2x4 sole plates to concrete foundation amakarevic Building & Construction 6 12-21-2010 09:28 PM
Is it SAFE not to use deck post concrete anchors? z_zk_z Building & Construction 3 06-28-2010 10:35 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 02:01 PM
How to secure bottom of 4 X 4 post to concrete? darsunt Building & Construction 6 08-19-2009 08:36 PM
refacing rubble concrete foundation footings Buck Building & Construction 2 10-25-2006 01:36 PM
