Post In Or Post On Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2007, 09:42 AM   #1
Rewards Points: 774
Post in or post on concrete
I live in Iowa. My footer depth needs to be 42". Is it better to do a post in concrete or attach post on top of concrete? Is one more stable then the other or easier/quicker?
cibula11 is offline   Reply With Quote
Old 06-07-2007, 01:43 PM   #2
I prefer to go on top of the concrete. The biggest reason is if you ever have a problem with the post it can be replaced much easier than if it where set in the concrete. I think it is easier to do that way also but that could be just because I have done it that way more.
warnerww is offline   Reply With Quote
Old 06-07-2007, 01:59 PM   #3
Rewards Points: 774
I had planned on doing post on top of the footer, but then I see so many people just putting the post right in the ground and throwing some cement in the hole. Is the lateral stability good with the post ON concrete?
Old 06-07-2007, 03:07 PM   #4
All you need to do is use an approved anchor bracket at the base and it will work great. I have sunk a piece of re-bar into the concrete then drilled a hole in the center of the post (in a pinch). I do not like this method as well but when you have a homeowner that refuses to look at a bracket and the inspector says OK then I will do it. I do not like re-bar because it can rust and only the weight of the structure holds the post down. When I do it I use a lot of construction adhesive.
Old 06-07-2007, 05:43 PM   #5
Rewards Points: 774
Would this be the same for setting a post for a fence? Or should I do that differently?
Old 06-07-2007, 09:39 PM   #6
Fence different story. Set them in concrete.
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
