Post/pole Hole Depth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 03:00 PM   #1
Rewards Points: 1,062
Question
post/pole hole depth
i am planning to have a 14w-10h garage rollup door to fence up the entry to my driveway from the alley (i live in a city). there is no actual garage, just a driveway so this door would act like a gate.
considering that a steel rollup door that size would be heavy, i was wondering what kind of depth for post holes i would be looking at. i will have to dig pretty close to the fences on both sides, which will make it more difficult to do it with an auger but i guess i can always hire someone for the hard work.
also, does anybody have a clue as to how many amps a motor for something like this would require? i am fine with anything up to 20A, 30 would be pushing it for my current resources.
Old 07-14-2011, 03:12 PM   #2
joed's Avatar
Rewards Points: 11,964
A standard 1/2 hp garage door opener should handle it. The door won't be that heavy to lift. It will be counter ballanced by the springs.
The Following User Says Thank You to joed For This Useful Post:
amakarevic (07-14-2011)
Old 07-14-2011, 03:15 PM   #3
Question
how many amps does 1/2 HP take ?
Old 07-14-2011, 03:16 PM   #4
Question
my guess would be around 3A. is that about right?
Old 07-14-2011, 03:52 PM   #5
Experienced
Jackofall1's Avatar
Just out of curiousty what do you plan to hang the openner on? A standard style garage door openner is hung from the rafters, as you don't have this are you planning on using a sky hook of some kind?
Would it not be better to consider a sliding gate as opposed to a roll up door?
Mark
Old 07-14-2011, 06:07 PM   #6
joed's Avatar
Not all door openers hang from the ceiling. Some mount to the wall beside the door. The door can go straight up also instead of overhead or be rollup.
Old 07-14-2011, 06:18 PM   #7
absolutely not. there will be two posts, one on each side, much like goal posts in rugby. the opener can hang on one of them.
i cannot have a sliding door because i want to have only two, not four posts. i now have just enough room to park two cars side by side, putting two more posts behind would mess that up.
Old 07-14-2011, 06:19 PM   #8
Experienced
Jackofall1's Avatar
Learn something new everyday.
Mark
Tags
garage door
Proper fix for floor joist simp82 Building & Construction 6 02-20-2011 01:29 PM
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 06:55 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
