Post And Pier Cladding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 07:44 PM   #1
post and pier cladding
Just bought a forclosure and previous owner had covered up foundation with dirt. We found out that part of the house, circa 1912, doesnt have a concrete foundation, only post and pier. I see dirt and rubble on the outer perimeter of about 28 feet in length. Should I remove this and put some sort of cladding in so critters cant get underneath the house? What should I do/use?
maverickaquatic is offline   Reply With Quote
Old 09-14-2010, 11:25 PM   #2
i've dealt with this scenario a few times.
what i've done is the following:
frame a simple skirting wall with PT 2X between posts and PT plywood. staple up 30# felt paper, then nail up metal lath, and run hardware cloth a foot or so down into the ground.
then you stucco the exterior. it winds up looking just like a real foundation, keeps the critters out, and can be insulated from the interior.
pretty quick and easy, too.
if and when you get to the stucco, i can walk you through it. pretty simple.
wombosi is offline   Reply With Quote
The Following User Says Thank You to wombosi For This Useful Post:
maverickaquatic (09-15-2010)
Post N Pier Foundation question. deck99 Building & Construction 9 03-05-2013 06:21 PM
post and pier foundation and veneer? wombosi Building & Construction 1 07-21-2010 08:33 PM
Post and pier addition to house with block foundation? Badfish740 Building & Construction 5 07-08-2010 09:14 PM
Dek Building- pier to post connection- necessary? k man Building & Construction 4 09-28-2008 06:21 PM
post and pier repair question tcameron Building & Construction 6 11-14-2007 08:07 PM
