Post And Joist Attachment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2013, 09:25 AM   #1
Post and joist attachment
I am planing a 12x18 screen porch addition with double 2x8 band joists. I want to notch the outside top of the 6X6 posts to accept the double joists flush. I understand this is the strongest way and I really lihe the appearence. However, if I notch the corner posts to accept the front and side joists there will only be a 2.5" square stub left to bolt through. Is this acceptable? What are some alternatives? Any suggestions will be greatly appreciated.
Thank You
tournament is offline   Reply With Quote
Old 02-09-2013, 09:36 AM   #2
Rewards Points: 13,960
That will work fine. Done all the time, most of the force is straight down.
Just double bolt it with 1/2" carrage bolts.
I counter bore the area where the heads of the bolts are so I can cover the rim joist with composit fashia so it's a nice clean look.
tournament (02-09-2013)
Old 02-09-2013, 10:50 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
I typically notch the 6x6 for a single ply then attach the outer ply to it. I'll then attach a wood cleat to the column under the outer ply. This satisfies the code requirements of beams, girders and joists bearing on 1-1/2" of wood. Once the ply is installed in the notch I use a metal strap tie that attaches to the column above and below the notch.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
AndyGump (02-09-2013)
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
how did they do this? band joist to post joetab24 General DIY Discussions 2 03-28-2010 01:33 PM
Angled Rim Joist on 6X6 SUPPORT POST usc529 Building & Construction 1 01-06-2010 07:15 PM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
