Old 06-15-2009, 06:48 PM   #1
I have gas!
Clutchcargo's Avatar
Post Caps needed.
Do I need any post caps or strap for this beam or can I just toe and end nail this in place?
I checked a few online resources and books and it looks like either an overkill post cap or toe nails.
My plan is to also drill 2 holes 2" from the edge and add 8" lag screws (Timberloks) which will tie into the end grain of the top plate (new adjacent wall).
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-15-2009, 07:45 PM   #2
Moderator
Post Caps needed.
Run a 24" flat strap horiz. across the top plt./beam, 1' on each. 18" strap vert. on post/beam, centered. 12" strap bent 2"around your post to the old last end stud(next to ply) bent 2". A35 Simpson is fine on both sides of other wall top plates, install vert. Be safe, G
Old 06-15-2009, 08:22 PM   #3
I have gas!
Post Caps needed.
Yep, that should keep if from getting away.
Great detailed answer, thank you.
Unable to Post in Google Chrome NRutman Site Help and Suggestions 0 12-31-2008 08:04 AM
post and pier repair question tcameron Building & Construction 6 11-14-2007 08:07 PM
