Post Beam Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 10:08 AM   #1
Rewards Points: 396
post beam question
Hi,
I have a front porch with gable roof so obviously there are posts and beams holding it up. The 2 side beams tie into the front beam over the posts. My question is how do you install 2 beams on one post where they meet?
detroittigerfan is offline   Reply With Quote
Old 07-30-2013, 12:34 PM   #2
Haverhill Trade 1965
With a ship lapped joint, or a mitered joint, or a butt joint centered on the post.
Duckweather is offline   Reply With Quote
Old 07-30-2013, 12:36 PM   #3
Rewards Points: 396
if you have two beams on a post how do you incorporate a post beam bracket to secure them?
Old 07-30-2013, 01:58 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
I usually use the ACE series from Simpson (I'm sure UPS has a similar type) on the exterior sides of the corner column.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-30-2013, 05:51 PM   #5
Rewards Points: 396
Good luck!
If you have a porch with a gable roof do you need a beam actually attached to the house like a ledger?
Old 07-30-2013, 06:01 PM   #6
GBrackins's Avatar
only if your ceiling joists are being ran back into the exterior wall of the house
Gary
Old 07-31-2013, 07:37 AM   #7
Rewards Points: 396
So, the ledger attached to house would support the ceiling joists. If you had a shed type roof then a ledger/beam on the house would be needed, correct?
Old 07-31-2013, 08:00 AM   #8
I would have to see what the bracket looks like. it depends if it is a corner or a joint in a continuous beam. I have never used brackets unless a specific one is called for.
Can I move steel eye beam post? Kev G Building & Construction 7 06-06-2013 07:19 PM
Post Beam Connectors,Pictures TRV Building & Construction 6 07-07-2012 08:25 PM
Beam to post question for a deck... dbldee20 Building & Construction 0 06-04-2012 09:24 AM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 09:31 AM
Moving ridge beam post brick_layer Carpentry 10 05-18-2011 10:43 PM
