Possible To Splice Multiple Pieces Of Rebar? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 06:14 PM   #1
DIYer
Rewards Points: 93
Possible to splice multiple pieces of rebar?
Is it possible to splice together multiple smaller pieces of rebar into one larger piece?
My goal is to use as many reclaimed materials and possible and I've collected many smaller rebar pieces
dwoloz is offline   Reply With Quote
Old 01-12-2011, 07:01 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
depending on the grade you might be able to weld it
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 01-12-2011, 07:03 PM   #3
Concrete & Masonry
Rewards Points: 470
Yes, and it's extremely common & acceptable to do so.
The lap is subjective, and you'll get opinions of anywhere between 12-40+ times the rod diameter. Personally, I like to use 16X most of the time, meaning 1/2" rod X 16 = 8" minimal lap.
jomama45 is offline   Reply With Quote
Old 01-12-2011, 07:36 PM   #4
DIYer
Rewards Points: 93
Thanks for the replies
So would it be sufficient to use wire ties to attach two or is welding or other stronger mechanical connection necessary?
Old 01-12-2011, 07:41 PM   #5
Civil Engineer
Rewards Points: 4,520
You have not indicated the purpose of the rebar. If you are simply reinforcing concrete, wire ties are fine. Welding is also acceptable, but much more difficult therefore less common. If you are doing something other than reinforcing concrete, you need to tell us what that is, and then revisit the question.
Old 01-12-2011, 07:49 PM   #6
DIYer
Rewards Points: 93
This is for reinforcing concrete, yes, should have mentioned that
Thanks for the help
Old 01-13-2011, 12:05 AM   #7
Registered User
Termite's Avatar
Welding is not a good option. It will weld, but it is not really an acceptable construction practice to weld mild steel rebar. If I saw someone do that I'd instantly require an engineer to sign it off. The proper method is to lap the bars with at least two wire ties per splice. The required overlap varies from place to place and also based on the structural conditions. 32 bar diameters is pretty much the minimum around here.....Check with your inspector regarding minimum lap where you live.
Since you live in the land of earthquakes I'd be willing to bet that the rebar splice requirements in your area are pretty restrictive.
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Gutters 1 piece vs. Multiple Pieces troyce1 Roofing/Siding 19 12-03-2008 01:46 PM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-04-2008 12:37 AM
Splice box/s between subpanel and main panel? SeanR Electrical 5 05-06-2007 03:21 PM
Is it OK to tape by multiple pieces of tape on one length? KUIPORNG Remodeling 3 01-21-2007 01:17 PM
