Possible To Remove Level In House? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 01:35 PM   #1
Possible to remove level in house?
Hi --
I am considering making a bid on a house, but wanted to get some feedback on potential (extensive) remodeling here first. The house is an unusual shape so that it can fit into a small lot -- it has many narrow, long floors (4) stacked on top of one another. The area directly above the living room is a space (an open second bedroom) that my husband and I wouldn't need. My question is: Is it possible to take out the floor/ceiling between these two levels, in order to create a two-story living room (and to let in a lot more light)? In case it matters, the bedroom is on the top floor of the house -- so there are no additional levels (other than the roof) sitting on top of it.
In the event this is theoretically possible, is it possible to estimate a range of costs for a large project like this?
Thank you!
caitlinshall is offline   Reply With Quote
Old 01-30-2013, 01:39 PM   #2
Rewards Points: 12,886
Not possible to even guess what this would cost.
20' ceilings might look cool but are a might mare to heat and cool.
Sure you can not find a house you like the way it is?
Old 01-30-2013, 01:52 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
There are several problems you would have to over come which would cost quite a bit. One right off hand is there is a double plate in the wall and without lateral support a slight wind could blow that wall in and your house would collapse. I will imagine you will change your mind about having that done once you get a hard cost on it. It would be best to get a contractor come out and give you a cost, no one here will be able to.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-30-2013, 02:43 PM   #4
Any sense of whether it's a five-figure renovation or six-figure?
Old 01-30-2013, 02:47 PM   #5
Framing Contractor
Originally Posted by caitlinshall View Post
Hi --
Thank you!
That type of project is done a lot. There's a lot involved and the cost is high....but it can be done. You need to have a professional come out to see your house......an architect or emgineer.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
BigJim (01-30-2013), PaliBob (02-01-2013)
Old 01-30-2013, 02:49 PM   #6
DIY staff
Rewards Points: 7,174
Need to see the structure-----is it a wood framed building---structural masonry---row house holding up the next building----balloon framed----
Just to much to guess at of estimate at all----start with a structural engineer--
Some times you get lucky---other times the entire structure needs to be rebuilt---
Done wrong the building might collapse---
Joe is faster than me---and very correct----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 01-31-2013, 01:42 PM   #7
Something I've seen done in cases like this is taking 2/3 of the joists out and wrapping the remaining ones in sheetrock. These remaining beams will help stiffen the building laterally (both in and outward).
Where I live this is a low $six-figure project, easily.
Call an architect to take a look at the existing framing. It should be a low or no-cost consult.
winnabago is offline   Reply With Quote
Tags
construction , construction estimating , home renovation
New heating system in old house - needs lots of help beengone HVAC 31 09-19-2012 01:00 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
split level house all A/C going downstairs BKphoto HVAC 8 05-04-2010 09:22 AM
Sewage Under House: How To Remove Smell?? rajivsab General DIY Discussions 1 11-25-2007 02:42 PM
looking to level my house floors terryt Building & Construction 3 03-10-2007 06:31 PM
