Possible To Move A Stairway ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 11:18 PM   #1
Send a message via Yahoo to markee
Possible to move a stairway ?
Looking to find a possible solution to this project
What I was hoping to do is relocate my laundry room upstairs to a attic space located in my sons room. It nice unused area right next to a bathroom with all the water and drain access .
Then I would close the entrance to it from inside the bedroom because it don't make sense to have to enter the laundry room from inside my kids room and open it on the other side of the wall.
Problem is when punched a nail thought the wall where i want to make the entrance it comes out over the top of the stairway
Can anyone think of a solution that won't brake the bank ?
Build a landing ?
Move the stairs some how ?
Possible to move a stairway ?-nail-hole.jpg   Possible to move a stairway ?-stairway-edit.jpg   Possible to move a stairway ?-dsc00427.jpg   Possible to move a stairway ?-dsc00429.jpg   Possible to move a stairway ?-dsc00432.jpg
markee is offline   Reply With Quote
Old 11-23-2009, 05:55 AM   #2
Chicago, IL
Michael Thomas's Avatar
Originally Posted by markee View Post
Build a landing ?
You could build a landing, provided that here was enough room at the bottom of the stairs to move them stairs outwards to provide for a code compliant landing without the stairs becoming too steep to meet code and while still providing adequate clearance at the bottom of the stairs. You could not just relocate those stairs in their current configuration however as they do not meet modern code (open risers, balusters which prevent hand rail from being readily graspable, for starters).
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 11-23-2009, 08:25 PM   #3
Registered User
Rewards Points: 5,516
I would concerned someone wrapped the purlin with cedar wood and removed the supporting struts, severely weakening that side of the roof structure. I hope no one sleeps up there next to an exposed mechanical pipes and attic with a louvered door separating them. A proper sized egress window is required for this bedroom. You may want to examine this if someone before you finished the attic (unsafely): http://www.taunton.com/finehomebuild...s-windows.aspx
Be safe, Gary
to move or not to move...the panel DangerMouse Electrical 7 02-24-2009 05:34 AM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 07:45 PM
Stairway loose asegal General DIY Discussions 4 12-02-2006 04:00 PM
need to move existing light. surfsupinhawaii Electrical 6 12-31-2005 08:54 AM
