Old 02-27-2007, 01:37 PM   #1
Possible finishes for OSB walls
Can I just sand, fill, and primer and then use texture paint on OSB interior walls? If so, what would you suggest as a filler? I have tried wood filler but it cracks. Would paintable caulk work? Does it need to be silicone?
homebuilder23 is offline   Reply With Quote
Old 02-27-2007, 07:01 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Huh?? OSB interior walls??
Please elaborate...never heard of such a thing and it doesn't sound right???
- Build Well -
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 07:55 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
