Old 08-30-2011, 11:01 PM   #1
Is it possible to dye cement mix?
I want to buy these preformed plastic trays for making a pathway and want to know if there's a way to dye the cement before pouring it in these trays.
Girly_girl is offline   Reply With Quote
Old 08-30-2011, 11:05 PM   #2
Tileguy
Bud Cline's Avatar
Yes. Home centers sell color pigments for just that purpose. The colors are limited but it is available.
The Following User Says Thank You to Bud Cline For This Useful Post:
Girly_girl (09-01-2011)
Old 08-30-2011, 11:10 PM   #3
Yes, I have a terra cotta colored patio and workshop slab. I like it, the color is through and through. The shades are muted, so don't would not expect bright/vibrant/strong color.
As said, if mixing it yourself the home stores will have powered color mix. If ordering concrete via a truck, talk to the supplier and they will have a selection of colors to choose from as well.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
Old 08-31-2011, 01:04 AM   #4
go to sher-wms & buy wtr soluble pigments - add pigment to the mix water - they've got 1,000s of colors - VOILA ! ! !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
The Following User Says Thank You to itsreallyconc For This Useful Post:
Old 08-31-2011, 08:06 AM   #5
Oil based pigments, i.e. paint pigments are not suitable for concrete. They are not recommended for highly alkaline materials and WILL fade in sunlight, especially greens and blues. Use only pigments designed for concrete.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 08-31-2011, 08:16 AM   #6
As stated above:http://www.quikrete.com/ProductLines/CementColor.asp
josall is offline   Reply With Quote
The Following User Says Thank You to josall For This Useful Post:
Old 08-31-2011, 08:17 AM   #7
Concrete & Masonry
Every "big box" store here has a few different liquid colors for a few bucks a bottle. Fairly easy to use, yet fairly difficult to keep consistent on separate pours spread out over several days/weeks. If you want a less muted color, there are a ton of enhancing sealers available that will bring out vibrant color.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 09-01-2011, 10:42 PM   #8
Originally Posted by josall View Post
I checked it out, nice to see the product I have to look for in the store. I guess this would be the one to do the job here. Hope it's not too expensive and comes out nice, thanks!
Old 09-02-2011, 12:17 AM   #9
Super Moderator
Montreal must have a brick yard or masonry supply house---this would be the place to look for colorants in larger bags or bottles----at much more reasonable prices,too.
Girly_girl (09-04-2011)
Tags
cement mix, dying
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 3 05-15-2011 02:45 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
