Possibility ?....or Ridiculous Shower Question? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 09:45 AM   #1
Possibility ?....or ridiculous shower question?
Im pretty sure this is a stupid question, but.....is it possible to move the shower curb out a few inches after the preslope, pan liner and the pan are already done? I was thinking,..... maybe, i could knock the curb away from the bed, add some mud to continue the edge of the preslope.... then extend the vinyl (is that possible) to come back over the curb or maybe use red guard or something to continue it. And then fix the finish layer of mud. or maybe just forget about the liner (but leave it in there) and then red guard the whole thing (walls, floor & curb)after extending all of the mud work. I want to move the curb so badly that I have convinced myself that this could be a possibility. Just grasping at straws hoping that someone will tell me ,No problem!...... Not likely.
this post will probably leave most people wondering if i should even be trusted to use power tools unsupervised
chris85016 is offline   Reply With Quote
Old 04-08-2011, 04:33 PM   #2
I know!!!
Hey I know you from another site. Wow . are you kidding
urgroutmaster is offline   Reply With Quote
Old 04-08-2011, 05:29 PM   #3
Rewards Points: 5,336
You can't do this successfully.
Ron
Old 05-06-2011, 10:50 AM   #4
taping backer board/drywall junction
Ok...I ended up ripping everything out and starting over. I moved the curb out & put a new liner in. Its much better. I do have another question, how do you tape the junction of backer board and drywall? Do you just fill the gap with thinset, mesh tape and then cover with joint compound ?
question on tile shower design racebum Tiling, ceramics, marble 19 12-19-2010 02:48 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Question: custom shower pan (problems) nuklep Plumbing 7 03-22-2010 06:18 AM
Bathroom Shower Window Replacement Question Jonnyonthespot Kitchen & Bath Remodeling 6 06-15-2009 11:54 AM
Question about tiny spaces in grout (shower) doogie88 Tiling, ceramics, marble 2 01-05-2009 01:51 PM
