Old 11-13-2012, 08:00 PM   #1
porch swing support
Hi
I am planning a new front porch addition and want to include a porch swing. It will be a shed roof with ceiling attached to the 2x6 rafters, 16"oc. What extra support needs to be added for a ceiling mounted porch swing? It would need to support 3-5 hunderd pounds just to be on the safe side. Any suggestions appreciated.
Ridgerunner is offline   Reply With Quote
Old 11-13-2012, 08:15 PM   #2
porch swing support
Since it's not built yet I'd tipple up the joist in that area. Drill a hole through the center joist and use 1/2 threaded rod in the hole with a fender washer and double nuts, then use an eye like this on the bottom side once the ceilings in place.
http://www.bing.com/images/search?q=...19CAE&first=40
Makes it easyer to install the ceiling material.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
hand drive (11-13-2012), Ridgerunner (11-13-2012)
Old 11-14-2012, 09:40 AM   #3
Estimator & Draftsmen
CanAmGuy's Avatar
porch swing support
First Question, what is the Span of the rafters?
CanAmGuy is offline   Reply With Quote
Old 11-14-2012, 03:53 PM   #4
porch swing support
Rafter span 8'...16" oc
Old 11-14-2012, 04:17 PM   #5
CanAmGuy's Avatar
porch swing support
Sorry, I should have asked this at the same time as the Span.
Do you know the pitch of the roof? Are you in an area that gets snow? If so, do you know the snow load for your area? Very critical that your rafters are correctly designed. Will the eave end of the rafter be supported by a wall or beam? Are you planning on finishing the ceiling of the porch and will it be flat or follow the slop of the roof?
Old 11-14-2012, 04:38 PM   #6
porch swing support
pitch 5/12, occasional snow, rafters to be supported by triple 2X6 beam in simson truss hangers (span 8' between posts) ...the ceiling will follow the slope of the roof...Not sure of snow load but my neighbor has the same set up (that's where I got the idea) and his has been standing there for the past 25 years...my main concern is water and wind...prone to tornados in this area and high winds...I was wondering about hurricane ties on the rafters as well as the joists??
Plans for Retrofitting Concrete Porch - Advice? BSponz1 Concrete, Stone & Masonry 1 05-07-2012 09:35 PM
Porch support.... chipbott Building & Construction 3 06-04-2011 02:40 PM
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 01:58 AM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 12:31 PM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 09:31 AM
