Porch Swing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 03:47 PM   #16
waterman1971's Avatar
Rewards Points: 154
Get a couple 1.5' pieces of extruded 2" angle, lag them to the sides of the rafter, drill some holes for the eye hooks, hang swing, drink beer
waterman1971 is offline   Reply With Quote
Old 03-07-2011, 05:36 PM   #17
Rewards Points: 590
sorry, I forgot to explain the images I posted. The first one is just a side shot of the rafter I cracked during my first attempt. The other side is nice and smooth. The second picture is of the first hole with the split and the eye bolt going into the wood with the tiny crack. It was the best shot I could get of that. What are these 1.5' extruded 2" angle you are talking about? My dad stopped by and had the idea of leaving the eye bolts where they are, sandwich the original beam with 2 more 2x6's and bolt all 3 together with 6 bolts with washers and lock washers and just tightening them up real good. It got dark so we are going to pick up on it again Wednesday. Do you think that idea will work?
nikeman is offline   Reply With Quote
Old 03-07-2011, 05:40 PM   #18
Rewards Points: 154
How much does this swing weigh?
Old 03-07-2011, 05:54 PM   #19
Rewards Points: 590
Its actually not that heavy (maybe 50-60 pounds max). Its made out of some sort of plastic or PVC or something so its light but really strong.
Old 03-07-2011, 05:59 PM   #20
Rewards Points: 154
How far is the rafter span?
The occupants will add additional loading, this must be taken into consideration.
Old 03-07-2011, 06:11 PM   #21
Rewards Points: 590
Thumbs down
It is 74" long and its a 2x6. The eye bolts are screwed in a good 4.5-5" into the beam so I do not think the weight is to much of an issue. The big issue is that the first attempt was a failure and I was not centered to the board causing it to split and drop the eye hook. And its just the one side that had the split..
Old 03-07-2011, 07:15 PM   #22
DIY staff
Rewards Points: 7,174
Sandwiching three 2x6s should be fine--- just make sure you hit the center and I think you're good!
Have fun,Mike
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 12:14 PM
Porch Swing Help x-factor Building & Construction 6 10-07-2010 08:06 PM
Hang porch swing from 2x6 rafter? fdecker Building & Construction 6 07-30-2010 06:37 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 09:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
