Porch Screening Choices - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2009, 04:39 PM   #1
Rewards Points: 334
Question
I am renovating my screen porch and was a little surprised by the choice in selection of screening. There is aluminum and fiberglass and everything from black to almost a white polished metal. What are the benefits and downsides of each type of screening and what would you recommend?
tripower is offline   Reply With Quote
Old 10-02-2009, 06:41 PM   #2
Remodeler
MinConst's Avatar
Vinyl screening is by far the most used now a days. It is easier to install and holds up well in the weather.
As for color or style. This depends on you and your tastes. Other than the size of the grid they all will do the job. There is new screening out that you can hardly see and then there is screening that is hard for the outside to see in. All this is your choice and you and your family are the best ones to choose.
Look at some samples at a screen shop they can explain the differences and will be able to actually see the difference in their displays. Standard screen is the most prevalent.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 10-02-2009, 07:41 PM   #3
Rewards Points: 334
You recommend Vinyl as opposed to fiberglass?
Old 10-03-2009, 06:21 AM   #4
Remodeler
MinConst's Avatar
No I just call it vinyl. My bad.
Web
One Man Shops
Old 10-03-2009, 08:35 AM   #5
Fiberglass screen with 'screentite' moldings works very well. Itwill keep screens tight for years. There is one porch I did 8 yrs ago and the screen is still as tight as when it was installed. It also makes repacing damaged screens easier.
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 09:31 AM
Screening in an existing porch sammyboy7 Building & Construction 1 07-11-2009 10:23 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
screening in porch rjr Building & Construction 1 04-26-2008 01:29 PM
