Porch Roof Support ?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2013, 06:06 AM   #1
Rewards Points: 91
porch roof support ??
how wide can a porch roof support extend away from the wall without porch posts? i am thinking of a porch to cover my 32" side door that extends out maybe 4' and i want to do a diagonal support instead of a ground supported post. thanks
gwilkrrs is offline   Reply With Quote
Old 05-27-2013, 01:42 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
not following your description, do you have some photos and a sketch of what you are wanting to do?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-27-2013, 04:56 PM   #3
Rewards Points: 91
Sorry- the door is 32" wide that the porch will cover- the porch will be a little wider then the door but project out 4' away from the wall- make sense now?
Old 05-27-2013, 06:52 PM   #4
GBrackins's Avatar
do you mean something like this?
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
gwilkrrs (05-28-2013)
Old 05-28-2013, 04:45 PM   #5
Rewards Points: 91
yes! excatly
Old 05-28-2013, 04:53 PM   #6
Rewards Points: 13,694
Problum is you can not just set those supports againt the siding. There has to be something soild behind them.
Old 05-28-2013, 06:29 PM   #7
Rewards Points: 91
so my location is new construction with open walls at this time- no sheetrock hung yet so the proper blocking will be installed. i can easily frame this i just wanted to make sure the distance out from the wall wasnt too great- i dont see a lot of brackets to buy for this so i will start looking for photos.......
Old 05-28-2013, 07:17 PM   #8
GBrackins's Avatar
here is a side view
Gary
Old 05-28-2013, 07:23 PM   #9
Rewards Points: 91
very nice. that is what i am thinking about.
Old 05-29-2013, 07:44 AM   #10
Bill Kearney
Rewards Points: 1,174
What does the building engineer have to say about the how the load is going to be carried? If you're in Maryland (as I am) then you'll want to be careful about planning for snow load on it. That and how the rain gutters will be situated.
wkearney99 is offline   Reply With Quote
Old 07-28-2013, 09:54 PM   #11
porch posts
hi can i use cedar 2x6 screwed together and glued as new front porch posts on my house . the wood expert at rona said yes
oands is offline   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Front Porch Roof Angle slakata Roofing/Siding 12 08-26-2011 08:46 PM
Shed Roof Screen Porch and Exisiting Chimney ksunderman Building & Construction 1 02-07-2011 07:08 PM
Building a Porch Roof Engus Building & Construction 1 04-06-2009 08:43 PM
porch addition roof dhag Building & Construction 1 07-21-2008 05:16 PM
