Porch Roof Ledger Attachment And Flashing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2012, 02:02 PM   #1
Porch roof ledger attachment and flashing
Hello, I'm building a porch roof (shed roof). In doing this I plan to attach 2 ledgers to my house. I'll have a 2X 10 as the top ledger for the roof and then a 2X8 for ceiling joists.
To attach the ledgers here is what I plan to do.
1. Take off the siding
2. Cut the house wrap and put a membrane on the house sheathing.
3. Put the house wrap under the membrane at it's bottom
4. Attach the ledger (pressure treated) to the house (without any washers or spacing behind) with ledger lok. The top ledeger woudl be on the wall studs and the bottom ledger would be on the rim joist.
5. Put some sort of flashing (not aluminum) where the flashing would go behind the house wrap and then extend over the ledger. (Do I even need to flash the lower ledger because the roof above should cover it?)
6. Put plywood on the roof and the flash again so that the flashing goes under the house wrap and over the shingles (or should it go under the shingle?)
Do I really need to flash twice or should I only flash on top of the shingles and expect that to keep the ledger dry. I think I could just do it once.
Hick
hick23 is offline   Reply With Quote
Old 08-18-2012, 03:16 PM   #2
Framing Contractor
Hick
No flashing twice an no pt ledger. The top ledger gets flashed after the sheathing is done along with putting the roof on. No need at all for flashing on the ceiling joists ledger.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
hick23 (08-18-2012)
Old 08-18-2012, 04:47 PM   #3
Thanks, so I don't need a PT ledger - I was thinking that would be needed - I guess no water would get to it though - so not needed - that way I guess I can use aluminum flashing too.
Old 08-18-2012, 04:54 PM   #4
Rewards Points: 150
Correct hick.
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-18-2012, 05:01 PM   #5
AHH, SPANS!!!
Rewards Points: 1,166
demo siding, build porch, get it dried in -osb, felt paper. Roof porch, put flashing over top of roofing against wall and then put siding back on. done
if you want to go with functional flashing consider a flashing wall vent combo that allows air flow and could increase roofing material life span. You need soffit ventilation to go along with the wall vent...
hand drive is offline   Reply With Quote
Old 08-18-2012, 05:04 PM   #6
The porch is just a covered porch - so aside from the roof it is open. Still shouldn't be any water getting to the ledger - but in general the porch is open.
Hick
Contractor Nightmare - Front Porch Addition my5sons Building & Construction 92 08-28-2015 10:43 AM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
