-   -   Porch roof ledger attachment and flashing (http://www.diychatroom.com/f19/porch-roof-ledger-attachment-flashing-154109/)
hick23 08-18-2012 02:02 PM
Hello, I'm building a porch roof (shed roof). In doing this I plan to attach 2 ledgers to my house. I'll have a 2X 10 as the top ledger for the roof and then a 2X8 for ceiling joists.
To attach the ledgers here is what I plan to do.
1. Take off the siding
2. Cut the house wrap and put a membrane on the house sheathing.
3. Put the house wrap under the membrane at it's bottom
4. Attach the ledger (pressure treated) to the house (without any washers or spacing behind) with ledger lok. The top ledeger woudl be on the wall studs and the bottom ledger would be on the rim joist.
5. Put some sort of flashing (not aluminum) where the flashing would go behind the house wrap and then extend over the ledger. (Do I even need to flash the lower ledger because the roof above should cover it?)
6. Put plywood on the roof and the flash again so that the flashing goes under the house wrap and over the shingles (or should it go under the shingle?)
Do I really need to flash twice or should I only flash on top of the shingles and expect that to keep the ledger dry. I think I could just do it once.
Hick
Joe Carola 08-18-2012 03:16 PM
Hick
No flashing twice an no pt ledger. The top ledger gets flashed after the sheathing is done along with putting the roof on. No need at all for flashing on the ceiling joists ledger.
hick23 08-18-2012 04:47 PM
Thanks, so I don't need a PT ledger - I was thinking that would be needed - I guess no water would get to it though - so not needed - that way I guess I can use aluminum flashing too.
Hammer450R 08-18-2012 04:54 PM
Correct hick.
hand drive 08-18-2012 05:01 PM
demo siding, build porch, get it dried in -osb, felt paper. Roof porch, put flashing over top of roofing against wall and then put siding back on. done
if you want to go with functional flashing consider a flashing wall vent combo that allows air flow and could increase roofing material life span. You need soffit ventilation to go along with the wall vent...
hick23 08-18-2012 05:04 PM
The porch is just a covered porch - so aside from the roof it is open. Still shouldn't be any water getting to the ledger - but in general the porch is open.
Hick
