Porch Posts Staning Alone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 09:11 AM   #1
porch posts staning alone
How do I attach my porch post to the porch deck, that I want to attach a hand rail to? The post will stand alone and only the rail will be attched to it. Do I just toenail screws / nails into the base to fasten it to the floor? That doesn't seem like it would too solid. Seems like the post would wobble.
Please help.
Toad is offline   Reply With Quote
Old 05-19-2009, 09:34 AM   #2
Rewards Points: 5,336
Posts like that are bolted into the framing below the porch deck. There's no surface mounted hardware that will work.
Ron
Old 05-19-2009, 09:37 AM   #3
porch post
Thanks Ron,
My problem is that I can't get under the deck.
I'm still researching. Had no idea this was going to be so difficult.
Toad
Old 05-19-2009, 10:31 AM   #4
Old School
Willie T's Avatar
You may (probably WILL) have to cut a hole (first drill, then open up the hole with a jig saw) in the deck, right next to some sort of solid structure beneath... be it a post (best) or the banding board running around your deck perimeter. This is what you will, hopefully, be able to attach to.
Try crawling under the deck (find a way! dig some dirt out, or use a mirror on a stick and a flashlight.) to see how and where all the solid stuff is installed, and where you might be able to use it for an attachment.
Willie T
Old 05-19-2009, 10:36 AM   #5
Originally Posted by Toad View Post
Thanks Ron,
Toad
Take the deck boards off so you can in from the top.
Ron
Pressure Treated vs. Cedar Posts for Porch missyz17 Building & Construction 15 08-22-2011 01:34 PM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 6 04-01-2010 06:41 PM
Advice for replacing porch posts pkovo Building & Construction 3 04-07-2009 07:59 PM
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 12:01 AM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 12:15 PM
