Porch Post Vinyl Or Metal To Stop Painting? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 07:49 PM   #1
porch post vinyl or metal to stop painting?
I have five porch post that are made of wood and have to paint every few years on my vinyl sided house that I will be re siding here soon. My question is what can I replace the porch post with or cover them with so I don't have to paint any exterior places I hate to paint. They are 3 1/2 x 3 1/2 square on the top and bottom and have been turned in about the middle two feet so I think I might have to pull these out not sure if they can be covered or is there something better I can just put in either metal or vinyl that will go with a vinyl sided house.
hobbyguy2002 is offline   Reply With Quote
Old 01-28-2008, 07:51 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,384
Ayuh,....
Vinyl is your Best bet.......
Old 01-28-2008, 03:37 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You would have to remove them to put a vinyl post sleeve on them. Or you can get them wrapped in aluminum. I've done that quite often, especially if the soffit and facia are aluminum also. There are also composite posts available that you can get in pretty decorative designs if you are pulling them out.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Painting a metal building. okinawap Painting 5 01-19-2011 10:43 PM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 04:34 PM
replace porch post? lrciii Building & Construction 3 07-16-2007 09:12 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
