Porch Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 12:22 PM   #1
porch help
I am adding a proch to the gable end of house. 6x6 Posts are 4 feet from house and 8 feet apart. I need header size and rafter size for South Michigan location. Pitch will be 5/12 or 6/12.
Thanks for your advice, Chuck81
chuck81 is offline   Reply With Quote
Old 02-25-2008, 12:54 PM   #2
MA licensed remodeler
iremod's Avatar
Try giving the perimeter dimensions.
Also, cathedral or no?
Why 4' from house with the posts and then changing to 8'. Why not make it consistent. Is it for a doorway?
iremod is offline   Reply With Quote
Old 02-25-2008, 01:03 PM   #3
Header is parallel to house 4 feet out on 6x6 posts 8 feet apart with no gable on porch, shed type roof
Old 02-25-2008, 02:33 PM   #4
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
2x6 Rafters and 2x8 beam should be plenty.
Double check with local building dept. for local codes
oldfrt is offline   Reply With Quote
Enclosing my porch Chefgjorvad General DIY Discussions 2 06-16-2007 12:46 PM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 10:34 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
