Porch Flooring At Top Of Steps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2010, 12:49 PM   #1
Wounded Mathematician
shtoink's Avatar
porch flooring at top of steps
Hi
I have just replaced about a dozen t&g flooring boards on my front porch (covered). Most of the boards are at the top of a set of wooden steps. The floor boards run perpendicular to the house and steps, thus presenting their cut edges along the top of the steps. The edge of the porch at the top step was previously covered with a strip of metal flashing. This original flashing was very old and damaged.
Is there a special type of metal strip/flashing that should be used for this? If so, what it the best way to attach it? Are there any better alternatives?
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 03-05-2010, 01:07 PM   #2
This is a stock item at any large hardware store.
Just tell them you need a stair nosing.
It will be aluminum or another non-corrosive metal.
Something like this:
http://www.hardwarestore.com/media/p...3_front200.jpg
Dairylander is offline   Reply With Quote
Open two story porch flooring blane11 Flooring 1 09-28-2009 07:26 PM
Swift Lock laminate wood flooring on steps? Leche4evr Flooring 1 08-29-2009 01:49 PM
Wooden steps (7 risers) up to front porch chrissygarden Building & Construction 1 08-18-2009 01:48 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
wood front porch steps dlhein Carpentry 4 05-11-2008 09:06 PM
