Porch Enclosure - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 06:32 PM   #1
dyer
porch enclosure
I have a covered porch open on two sides , floor is concrete with rowlock. I plan to enclose with sliding glass doors . Do I need to use treated 2x4 for the sill plate ?
stheman is offline   Reply With Quote
Old 06-16-2010, 07:14 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
S, Welcome to the Forum
By rowlock, do you mean interlocking concrete pavers? Can you post a pic?
If the surface is flat to within 1/4" over the width of a door, I would think that a sill would not be required. Aluminum framed Sliding glass doors on a slab foundation are mounted directly to the concrete.
In brickwork the term rowlock refers to special shaped bricks.
http://www.brick.com/architect/specialshapes.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Last edited by PaliBob; 06-16-2010 at 08:03 PM. Reason: added specific type of glass door
Old 06-16-2010, 07:18 PM   #3
DIY staff
Rewards Points: 7,174
Treated sills are used under any framing that contacts concrete.
The doors themselves might be able to be installed on the concrete--If it is close enough to level to be shimmed and grouted.
A picture would be nice.--Mike--
Old 06-16-2010, 07:59 PM   #4
Tool Geek
PaliBob's Avatar
More thoughts on rowlock
If the open sides rowlock of the porch is made of rectangular shaped concrete pavers bonded to a poured concrete porch then the rowlock may just be removed for what IMO would be a cleaner design.
Thanks to Wikipedia, I may have a better image of your porch with the open sides edged with rowlock
Click here for rowlock
Disclaimer
& Stay Safe
.....Bob Lavery
How to Winterize Porch subdude Remodeling 0 02-04-2010 09:00 PM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Porch Enclosure Vinyl post stillworking Carpentry 1 03-18-2008 05:07 PM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 06:01 PM
