Porch Construction Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 02:55 PM   #1
porch construction question
When you have a porch the rafters sit on the header beam supported by porch columns, correct? Where the rafters meet the ridge what support that ridge? Is it just attached to the house framing?
markharmon is offline   Reply With Quote
Old 07-02-2013, 03:24 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
there is usually a 2x ledger against the house that bolts to house and rafters are cut to it or the rafters are set into the wall attaching to the sides of the studs and then blocking added to form a type of ledger inside the wall.
hand drive is offline   Reply With Quote
Old 07-02-2013, 06:31 PM   #3
Would it bolt to the studs from the interior of the house or the double top plate of the walls?
Old 07-03-2013, 09:23 AM   #4
AHH, SPANS!!!
the ledger bolts to the outside of exterior wall if that is how it is built. if the top of roof is placed up tight under the house overhangs then it could possibly bolt to the double wall plates but most likely not because the underside of the house soffits being lower than the top plates.
6" Halo remodel construction recessed housing bulb safety question yrralrellim Electrical 5 04-02-2013 04:34 PM
interior construction project question kindofsudden Building & Construction 5 11-07-2012 10:51 AM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
New construction porch question bayoudonnie Carpentry 3 09-23-2006 03:11 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 05:20 PM
