Old 07-03-2012, 04:38 PM   #1
Smile
porch columns rotted at the base
Porch columns rotting on bottom of columns, near base.
also don't know if the columns are load bearing or not.
Any solutions to problem other than replacement?
Please check out attached pictures!
Thanks!
Joe
josephb is offline   Reply With Quote
Old 07-03-2012, 10:45 PM   #2
AHH, SPANS!!!
Hi Joe, it is probably best to treat those as load bearing and change out with new posts, fiberglass instead of wood preferably .
hand drive is offline   Reply With Quote
Old 07-03-2012, 10:52 PM   #3
Time for new ones. Wood will just rot again.
Vinyl or Fiberglass ones and never have to work on it again.
I'm sure someones going to suggest bondo, some sort of wood filler.
It will just be a patch job and your going to have to do it all over again.
need to know if i have built a strong enough foundation and column's for my covered porch, there are 4. jackhill Building & Construction 6 01-24-2012 07:47 PM
Porch columns/supports degnem Building & Construction 0 06-07-2010 08:58 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
Need to make bases for porch columns rafaell General Discussion 3 09-01-2008 10:32 PM
Repainting Columns on front porch R Parker Painting 10 04-17-2006 09:37 AM
