Porch Clearances Near The Property Line - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 04:52 PM   #1
Porch clearances near the property line
I am looking to build an overhead porch connected to the front house, however Im not sure if there has to be a certain distance between the property line and the end of the porch width to be able to pass inspection in Los Angeles. Does any one know what that clearance must be?
chinchillak is offline   Reply With Quote
Old 06-22-2011, 05:08 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
The only way to find out is to ask the local building and zoning office.
They vary widely and individual properties may have different requiremnts.
Dick
concretemasonry is online now   Reply With Quote
Old 06-22-2011, 10:13 PM   #3
Rewards Points: 5,336
Many localities do not allow you to add a large structure to the front of the house.
Entrance foyers are allowed around here, but front porches are not.
Ron
B. Franklin 1759
Tags
clearance , pass inspection , porch
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Property line dispute Cubey Off Topic 27 04-20-2010 01:09 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
