Old 05-08-2012, 12:30 PM   #1
porch ceiling occasional ice dam leak
I have a porch that was enclosed many years ago. It has original beadboard ceiling. I don't know if there is insulation up there unless I take out some of ceiling. Ok, every couple of years, I get a leak through the ceiling after we have heavy snow and then melt/freeze. Looking for wisdom on whether this is more about the roof needing repair or something to do with the porch being heated and not insulated. Any thoughts welcome. I am a complete newbie and trying to teach myself.
pfazio is offline   Reply With Quote
Old 05-08-2012, 12:41 PM   #2
Post a picture.
Most enclosed porchs I've got stuck working on do not have enough slope, no or not enough insulation, and no venting. All great ways to get a roof leak from a ice dam.
pfazio (05-08-2012)
Old 05-08-2012, 12:50 PM   #3
cortell's Avatar
Well, the most obvious question here is...do you witness ice dams forming? If so, then that's almost certainly due to insufficient insulation and/or insufficient venting in the attic space.
Now, is that the cause of your leak? Could be. If the leak is in the middle of the ceiling, it's less likely (but not impossible) and you might have a roof leak. If the leak is near the walls, it's likely caused by the ice dams.
cortell is offline   Reply With Quote
Old 05-08-2012, 07:56 PM   #4
Well, that is interesting. The leak does drip from center of porch.
Old 05-09-2012, 11:40 AM   #5
cortell's Avatar
It could be a roof leak instead of an ice dam issue, then. But if you don't see the problem during heavy rains, then I'm doubtful that's the case and you what may be happenings is that the water that backs up from the ice dam rolls down a sagging joist and releases near the center of the ceiling.
Tags
ice dam, porch ceiing, roof
Experiences with vinyl soffit for porch ceiling? NancyNGA Carpentry 4 07-12-2011 09:39 AM
Apartment water leak - questions haris General Discussion 2 03-23-2011 08:26 PM
Porch Ceiling hjd General Discussion 6 09-16-2010 05:19 PM
Porch Ceiling suzzettef@aol.c Building & Construction 1 09-09-2009 07:26 AM
Help Ceiling Leak on 1st Floor EllenMR Carpentry 4 09-23-2008 10:44 PM
