-   -   porch ceiling occasional ice dam leak (http://www.diychatroom.com/f19/porch-ceiling-occasional-ice-dam-leak-143110/)
pfazio 05-08-2012 12:30 PM
I have a porch that was enclosed many years ago. It has original beadboard ceiling. I don't know if there is insulation up there unless I take out some of ceiling. Ok, every couple of years, I get a leak through the ceiling after we have heavy snow and then melt/freeze. Looking for wisdom on whether this is more about the roof needing repair or something to do with the porch being heated and not insulated. Any thoughts welcome. I am a complete newbie and trying to teach myself.
joecaption 05-08-2012 12:41 PM
Post a picture.
Most enclosed porchs I've got stuck working on do not have enough slope, no or not enough insulation, and no venting. All great ways to get a roof leak from a ice dam.
cortell 05-08-2012 12:50 PM
Well, the most obvious question here is...do you witness ice dams forming? If so, then that's almost certainly due to insufficient insulation and/or insufficient venting in the attic space.
Now, is that the cause of your leak? Could be. If the leak is in the middle of the ceiling, it's less likely (but not impossible) and you might have a roof leak. If the leak is near the walls, it's likely caused by the ice dams.
pfazio 05-08-2012 07:56 PM
Well, that is interesting. The leak does drip from center of porch.
cortell 05-09-2012 11:40 AM
It could be a roof leak instead of an ice dam issue, then. But if you don't see the problem during heavy rains, then I'm doubtful that's the case and you what may be happenings is that the water that backs up from the ice dam rolls down a sagging joist and releases near the center of the ceiling.
