Old 11-29-2012, 06:15 AM   #1
popping noise coming from walls
I have noticed a more consistent popping sound from my master bathroom wall. It appears to be a pop at least once a minute, and it is mostly heard at the quiet time of the night. When the central air is on the entire room will make small pops which i am assuming from the pressure of the air circulating. It disipates when the air is off. Any suggestions?
Dan-diyer is offline   Reply With Quote
Old 11-29-2012, 06:46 AM   #2
Sounds like expansion/contraction of the ductwork when there is cold/hot air moving thu them
danpik is offline   Reply With Quote
Old 11-29-2012, 08:46 AM   #3
Could be ductwork or just house materials like wood expanding/contracting due to temp change. Plumbing sometimes makes clicking sounds for some time after use.
mikegp is offline   Reply With Quote
Old 11-29-2012, 09:37 AM   #4
sdsester's Avatar
Where are you located? You might want to update your profile with basic information.
Is this new construction you are living in? I have seen drying douglas fir studs pop drywall nails right out as the dried out.
Where I lived, humidity changes are extreme. Doors and windows you can barely get open and closed in the summer rattle at times with extra space in the dry winter months of January and February. Lots of static electricity sparks too because the air is so dry. I once saw a grand piano top split when it was moved from New Orleans to Chicago in the winter.
sdsester is online now   Reply With Quote
Old 11-29-2012, 04:25 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
if its hvac causing it its do to lower grade steel used in the ductwork its more likely to cause popping noises.. plumbing will do it if the pipes arent properly strapped to the framing
woodworkbykirk is offline   Reply With Quote
Old 11-29-2012, 11:56 PM   #6
Vinyl siding can do this too.
mae-ling is offline   Reply With Quote
Old 11-30-2012, 06:51 PM   #7
Solutions (handyman)
All the above are correct. I just hope it isn't a crunching sound and/or the pitter patter of little feet making a home inside your walls.
Mark Harvey is offline   Reply With Quote
Loud noise coming from squirrel cage? kcrossley2 HVAC 6 09-10-2012 08:46 PM
Rain seepage stain removal and sealing on bare block walls Peipei9 Concrete, Stone & Masonry 2 03-29-2012 06:37 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 08:45 AM
Popping noise in the flat roof mtrx Building & Construction 6 03-15-2010 11:18 PM
high pitch noise coming from oil line pingers7 HVAC 2 11-29-2006 08:41 AM
