-   -   popping noise coming from walls (http://www.diychatroom.com/f19/popping-noise-coming-walls-165055/)
Dan-diyer 11-29-2012 05:15 AM
I have noticed a more consistent popping sound from my master bathroom wall. It appears to be a pop at least once a minute, and it is mostly heard at the quiet time of the night. When the central air is on the entire room will make small pops which i am assuming from the pressure of the air circulating. It disipates when the air is off. Any suggestions?
danpik 11-29-2012 05:46 AM
Sounds like expansion/contraction of the ductwork when there is cold/hot air moving thu them
mikegp 11-29-2012 07:46 AM
Could be ductwork or just house materials like wood expanding/contracting due to temp change. Plumbing sometimes makes clicking sounds for some time after use.
user1007 11-29-2012 08:37 AM
Where are you located? You might want to update your profile with basic information.
Is this new construction you are living in? I have seen drying douglas fir studs pop drywall nails right out as the dried out.
Where I lived, humidity changes are extreme. Doors and windows you can barely get open and closed in the summer rattle at times with extra space in the dry winter months of January and February. Lots of static electricity sparks too because the air is so dry. I once saw a grand piano top split when it was moved from New Orleans to Chicago in the winter.
woodworkbykirk 11-29-2012 03:25 PM
if its hvac causing it its do to lower grade steel used in the ductwork its more likely to cause popping noises.. plumbing will do it if the pipes arent properly strapped to the framing
mae-ling 11-29-2012 10:56 PM
Vinyl siding can do this too.
Mark Harvey 11-30-2012 05:51 PM
noise
All the above are correct. I just hope it isn't a crunching sound and/or the pitter patter of little feet making a home inside your walls.
