Poorly Placed Joists In Home Being Remodeled - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 10:29 PM   #1
Rewards Points: 33
Poorly placed Joists in Home being remodeled
Can someone help me understand what, if any, would be the structural differance between these two in terms of their ability to carry a load?
temp image link
https://images.4chan.org/diy/src/1341718838242.gif
Ghengisconrad is offline   Reply With Quote
Old 07-07-2012, 10:57 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
sorry I could not view your gif, my security software doesn't like the site ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-07-2012, 11:39 PM   #3
Rewards Points: 33
This could be it.
Old 07-08-2012, 12:34 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
What are we looking at?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 07-08-2012, 07:32 AM   #5
Rewards Points: 33
Shmyeah, the view IS from above; I'm remodeling my house, and the second one is what some floor joists look like.
I worried that there would be severely diminished struictrual support given to it because of the bend, but was unable to phrase the situation to even google it.
This is just a snapshot of an whole joist system of 2x8 firs from the 1920's that spans 13' here.
Old 07-08-2012, 07:51 AM   #6
Civil Engineer
Rewards Points: 4,938
Can you post the diagram with an accurate scale on it. Or take a photo. The diagram posted suggests an extraordinary amount of bend in the joist, which seems unlikely.
Daniel Holzman is online now   Reply With Quote
Old 07-08-2012, 08:03 AM   #7
Rewards Points: 33
as you can see, it bends inward almost immediately to join with its friends.
Old 07-08-2012, 08:05 AM   #8
Rewards Points: 33
picture not so good, but you get the idea
Old 07-08-2012, 08:09 AM   #9
DIY staff
Rewards Points: 7,174
That looks bad---what is holding it up? Doesn't look like it's properly supported.
Old 07-08-2012, 08:35 AM   #10
Rewards Points: 33
balloon framing man. That works they say. I would tend to trust them. This has stood for almost 100 years so...
Old 07-08-2012, 08:40 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
yep, those original studs probably have 40 penny nails spiking them to the joist.
the new studs that were added are the ones that are not straight and that is no problem, the original ones are straight and holding the ceilings/upstairs floors up.
hand drive is offline   Reply With Quote
Old 07-08-2012, 09:11 AM   #12
Rewards Points: 33
As a side note; sense I DO have all the walls open and such, would I be better off kind of 'bracing' those side joints so it looks more like standard framing? Or is it a waste of time and lumber?
Old 07-08-2012, 09:13 AM   #13
Rewards Points: 33
also, fyi, the new joists have 5/16" lag bolts holding them in... as well as a &$*(#U#*($ load of construction adhesive so...
Old 07-08-2012, 09:23 AM   #14
I don't have a clue what is going on here.. Balloon framed? New joists? Bowed 2x4's? What is it that you are doing? Adding new joist and trying to sandwich them in between 2x4's? Why are you adding new joist? I'm lost, and am having trouble visualizing what your trying to accomplish by your photo.
CopperClad is offline   Reply With Quote
Old 07-08-2012, 09:39 AM   #15
AHH, SPANS!!!
if one out of the 2 double added studs were placed under the ceiling joist and installed in a straight fashion then that would have been ideal, but it wasn't. I'm not sure that the lags in the new studs are even holding much because of how the studs flex with the bend in them, that compromises strength and integrity. the original straight studs are probably holding up more than the add on studs.
Sistering Joists and Adding a Beam Mikeman Building & Construction 6 09-30-2011 08:11 PM
bracing floor joists - wobble wobble noahrexion Building & Construction 5 01-21-2011 11:33 PM
Double floor joists harsuwind Building & Construction 3 09-15-2010 07:35 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
