Poor Man's Shed Ventilation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 04:33 PM   #1
poor man's shed ventilation
I'm putting together plans to replace the cheap aluminum shed in my backyard (which collapsed under the snow) with a real, 10'x13' stick built one. I've done research enough to know how to make the trusses, and framing the walls is a no-brainer.
however,
I'm thinking it might be nice to lower the expected ambient temperature in the shed. In the summer, the aluminum shed was a sauna, so I figured I'd put in some sort of minimalistic venting. The shed will not be insulated, it's just meant to store the mower, bikes, etc.
The roof I am planning is a 6/12 pitch, gable-type roof. I was thinking I'd put vented soffit in, and then, in the highest point of the "triangle" of the gable, put some sort of exhaust vent. I don't really want to deal with flashing around a vent in the roof. I've never done roofing, so I want to keep it simple.
The shed is 10 feet wide, so using the 6/12 pitch of the roof, that would place my vent about 2.5 feet above the soffit. would this get me enough air flow to make a little difference, or is this not going to do enough to bother going to the trouble?
ROB_IN_MN is offline   Reply With Quote
Old 02-21-2011, 04:55 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Incorporate a cupola and make it a cool looking shed....
tcleve4911 is offline   Reply With Quote
Old 02-21-2011, 05:00 PM   #3
I forgot to mention, we're planning on paying off this house in a couple years and moving. it's a starter house, so I'm saving my fancy shed for the backyard of my dream home
Not to mention that a cupola defintely does not qualify as a simple, lay down some shingles, roof!
Old 02-22-2011, 07:13 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Sure it does...........
Cut your sheathing out
Shingle the whole roof minus the ridge cap
Install the cupola right over the shingles
Install the ridge caps
Done
The Following User Says Thank You to tcleve4911 For This Useful Post:
Willie T (02-22-2011)
Old 02-22-2011, 07:43 AM   #5
Rewards Points: 84
Another thought might be to put a small, screened, awning window in each of the gable ends. You could open them once in the spring, and close them again in the fall. If you want to dress it up a bit, you could use octagon ones.
Old 02-22-2011, 07:59 AM   #6
Old School
Willie T's Avatar
Personally, I would just install a full length ridge vent. They install easily and simply, just about like the cupola Cleve mentioned.
Willie T
Old 02-22-2011, 08:25 AM   #7
Agreed ^. Being that it's a shed, there will be enough gaps to let air in for the ridge vent to draw out
mrgins is offline   Reply With Quote
Old 02-23-2011, 10:23 PM   #8
thanks for all the advice guys.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 11:35 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
ventilation in new shed roof addition berta Building & Construction 4 10-21-2008 04:33 PM
