Pool Solar Reel Cranks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2011, 08:30 PM   #1
pool solar reel cranks
Any ideas on how to make your own crank to roll up solar cover if you already have the aluminum rod?
bcharles is offline   Reply With Quote
Old 05-11-2011, 01:33 PM   #2
Make-shift Solar Cover Reel
Hi bcharles,
I like your ingenuity. I think you could maybe use a tire iron. It would have the same shape and functionality as long as it fits into the rod properly. I do know that you can find solar cover reels for pretty cheap, around $40. Hope this helps, and if you do find a way to make the reel, please post a picture!
PaulSimmons is offline   Reply With Quote
DIY Pool cover reel system tips timp General DIY Discussions 15 06-15-2011 08:32 PM
Inground Pool Leak - suggestions needed hravenkel Plumbing 10 03-21-2011 08:39 PM
Pool Cement Apron Issue ajdevoll Building & Construction 7 09-08-2010 09:57 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
