Pool House Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 09:37 PM   #1
pool house foundation
I am planning on building a 14x14 shed/poolhouse and am not sure what is necessary for the foundation....there is no code requirements for this building in my area so that is not a consideration.
My question.....is a concrete slab absolutely necessary or would it be fine building it on pier blocks or on skids?
Frost heave is really not an issue. It will have electricity and water. The water will be seasonal and delivered via a garden hose so not worried about attatchment of utilities.
My only concern is the building moving since it will be a psuedo living area with flooring and sheet rock.
stemit1 is offline   Reply With Quote
Old 02-28-2010, 10:02 PM   #2
Why not
If its for light utility use and you plan on having it awhile, just throw down a small 4" pad. This will help keep moisture out of the unit and the drywall from discoloring. It shouldnt be too expensive. You could do the concrete work yourself
noahweb is offline   Reply With Quote
Old 02-28-2010, 10:35 PM   #3
Will the pump & filter be inside?
My existing pool caban had a cement pad except where pump/filter were located
I added on w/only a 12" foundation to keep critters out
I want to be able to take up the floor in case I need to redo plumbing
I'll put down gravel/sand & apvers on the inside
Old 03-04-2010, 11:19 AM   #4
I work for Advanced Foundation Repair in Texas. I am not sure where you are located, but if your home is in an area with expansive soils, both slab and pier and beam foundations will move. If you want to avoid movement, build a pier and beam, but rest it on deep drilled piers. How deep you need to go will be a function of your soil conditions (how deep is the active zone). www.foundationrepairs.com
Sonya_AFR is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
New Pool Installation Question Carla_Il Electrical 19 03-10-2010 08:33 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
HELP !!! Friends house has crumbling foundation! hellothere123 Building & Construction 1 09-05-2008 05:34 PM
