Pool House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 11:55 PM   #1
Pool house
I am looking to build a 14x16 pool house.
My question is I would like to extend the roof 8 feet on the 14 foot side to create a covered patio area. there would be a post on the two front corners of the roof for support.
I spoke with a home builder friend and he suggested that if I wanted to do this that I would need to use engineered beams that would run the entire length of the roof.
Is this really necesary or is he just over engineering it?
stemit1 is offline   Reply With Quote
Old 02-08-2010, 12:01 AM   #2
jlhaslip's Avatar
Rewards Points: 1,560
engineer your own beam by nailing some 2 by's together.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-08-2010, 06:53 AM   #3
Will the 8' roof have support posts at each end ?
When you say off the 14' side is that off one side of the roof ?
Or the pool cabana will be 14' long + another 8' roof without walls & its 16' wide ?
Car ports are built all the time without an engineered ridge beam
Old 02-08-2010, 10:01 PM   #4
Yes the building is 14 feet deep with an additional 8 ft covered patio and 16 feet wide. I will have a post at the front corners of the overhang.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
The sales ad. didn't mention the house comes with a pool Stephen S. Roofing/Siding 8 01-11-2010 08:24 AM
House Ventilation oldgrunt Roofing/Siding 8 11-11-2008 03:22 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
