Polyurathane Or Silicon Caulk Outside? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 11:04 AM   #1
Rewards Points: 640
Polyurathane or silicon caulk outside?
When you have a protrusion going outside and something like a pipe going through it, is it better to use polyurathane caulk or silicone caulk? I've seen some inspection reports balk at silcone caulk outside on pipe protusions to fill the gap between them and the wall / siding, what is correct or generally preferred?
BlueBSH is offline   Reply With Quote
Old 01-12-2012, 12:25 PM   #2
Rewards Points: 1,092
Silicone can't be painted well. I'd use Great Stuff if the gap is not huge, trim it, and paint it (several coats will be necessary), or a paintable caulk.
Old 01-12-2012, 01:03 PM   #3
Rewards Points: 13,694
Depends on how big the gap is on how to fix it.
Old 01-12-2012, 01:09 PM   #4
Rewards Points: 640
I'm just talking the little gap between a pipe and siding, say a 3" pipe went out and you cut 3.6" to get it through since the PVC pipes outer diameter is 3.5" you'd have that 1/10th an inch for water to seep back in or air to infiltrate back in
Old 01-12-2012, 01:13 PM   #5
Any time a pipe goes through vinyl siding there should have been a siding block for it to go through.
(you did not mention what type siding you have)
I'd just use Alex 230, it's work for me for many years, we go through at least a case a week.
Old 01-12-2012, 01:26 PM   #6
Rewards Points: 640
This house has just plain old vinyal siding, none of the pipes had anything put around them they just drilled through and ran the pipes through, only thing with J blocks around it was the electrical outlets
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 36 02-24-2016 02:01 PM
Remove silicon caulk acerunner Remodeling 6 11-16-2011 02:55 AM
grout, sealer and silicon caulk drdad Kitchen & Bath Remodeling 7 09-13-2011 11:53 AM
What type of Caulk to Use Einhorn General DIY Discussions 19 08-21-2011 02:50 PM
Plumbers putty or Silicon Caulk? sukhenkoi Plumbing 2 04-21-2010 06:51 AM
