Polymer Wall Base - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 06:54 AM   #1
polymer wall base
we are enclosing a covered concrete patio. Is there a load bearing polymer material to put down on the concrete on which to build the wall?
John Drew is offline   Reply With Quote
Old 04-27-2012, 07:50 AM   #2
cortell's Avatar
Rewards Points: 504
I'm not sure I understand the question, but it sounds to me like you're asking about a poly sill sealer
http://www.reflectixinc.com/basepage...&PageIndex=627
cortell is offline   Reply With Quote
Old 04-27-2012, 10:40 AM   #3
Rewards Points: 13,960
How close to grade is the slab?
Old 04-27-2012, 11:24 AM   #4
Too Short? Cut it Again!
Not sure I understand what you mean either. A sill sealer would not be load bearing and would not factor in at all. Are you looking for an alternate material to wood, in a polymer or composite, for your wall baseplates? Because?
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Replacing 240V Wall Heater with 240V Base Board Heater jasoncw Electrical 7 11-26-2010 10:39 AM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
removing/replacing base molding on brittle plaster wall alt Remodeling 3 09-08-2009 09:28 PM
